707lineman
Sep 17, 2017Aspirant
R7000 AP Mode Can't reach admin panel after modem change
So my setup before I changed it had a Arris Cable modem from Suddenlink, a AC1900 Router for wifi (Wifi was turned off on the Arris Modem) I connected a cat5 from the port of the modem to the "inter...
- Sep 17, 2017
Try a factory reset on the router. Reset the modem also. Then disconnect the wired connection between the router and your gamer and see if it still connects the old way. It should work the way you have it but sounds like something wierd is going on.
sktn77a
Sep 17, 2017Virtuoso
Have you tried resetting the router?
- 707linemanSep 17, 2017Aspirant
Yes, not a factory reset but a soft reset
- sktn77aSep 17, 2017Virtuoso
I changed the AC1900 over to 192.168.0.104 It works now. I have to change the other devices to that ip range which might not be possible. Thanks for the help
