707lineman's avatar
707lineman
R7000 AP Mode Can't reach admin panel after modem change
So my setup before I changed it had a Arris Cable modem from Suddenlink, a AC1900 Router for wifi (Wifi was turned off on the Arris Modem)  I connected a cat5 from the port of the modem to the "inter...
  • sktn77a's avatar
    sktn77a
    Sep 17, 2017
    Try a factory reset on the router.  Reset the modem also.  Then disconnect the wired connection between the router and your gamer and see if it still connects the old way.  It should work the way you have it but sounds like something wierd is going on.
