Poppiesanta
May 26, 2019Aspirant
R7000 appears to be a bottle neck. The internet speeds are fast, but with 20 2.4 & 6 on 5g!res
R7000 appears to be a bottle neck. The internet speeds are fast, but with 20 2.4 & 6 on 5g, the user response experience is slow. I don’t have metrics but busy times, Facebook vids are slow to load o...
- May 27, 2019
Poppiesanta, well this all sort of makes sense now Larry.
First, Smart Connect might not be needed. That however isn't probably the problem. "Smart Connect" is supposed to 'sense' the speed (802.11 speed rating, N, G, AC, etc.) and assign the faster devices to the 5Ghz band which is generally faster. Doesn't always do a good job, and you usually are better off manually assigning devices to each band based on the capability of the device. In some instances putting a slow device on a faster band will slow that band down.
Traffic Meter can slow you down too, don't use it unless you really have a need for it. However, with only 10Mbps coming in QoS can help, but it would only help the 'streaming' and probably 'gamer players' at the detriment to other users.
I do sort of question your speed tests? You said "ISP = Xplorernet in Ontario. Subscribed to 10" but on the screenshot posted on 5/24 @ 3:10PM you got 36Mbps? Doubt it and that makes me wonder about the other tests?
This part could be part of the problem, "this router is shared by families is a Trailer Resort.". So you really don't know at any given time how many devices are really connected, nor what they are doing? Netflix for example can use 2Mbps even of the signal.
So the next question is the firmware. You said "Firmware 1.0.9.64. The last upgrade was 2 weeks ago". That f/w is problematic, and many many people have problems. Did this all work before that was updated to it? If so, go back to V1.0.9.42.
However, 10Mbps in could be the base problem here, NOT the router. Try turning off Traffic Meter first. See if that improves. Next enable QoS and do the speed test on that page. See it that improves. Still a problem, go back to the older firmware and see if that improves. If not, I'd think your problem would the incoming ISP isn't as fast as you need? I could be wrong if it worked fine before though?
IrvSp
May 27, 2019Master
In addition to shadowsports questions, have you run a SPEED TEST on any device to see what the speeds are?
Have you tried OTHER Browsers? Have you tried Firefox in SAFE MODE? Some add-ons can really slow things down, and some on certain sites only?
Do you have SMART CONNECT on?
What devices are on the 2.4Ghz band (Attached devices would show that)? Are ALL the same rated speeds (N, G, etc.)? Speed drops to the slowest device attached.
Are you having the problem on BOTH SSID bands or only one?
Have you tried changing SSID channels, you might be on a crowded one or one that has interference?
- PoppiesantaMay 27, 2019Aspirant
Thanks for your assistance
I expected the speed test on the router to be most accurate. My laptop doesn’t have an ethernet port.
The slow response is seen across a variery of devices. Because on the environment (See Below) would I have to visit all devices, I attacked a list of
Smart Connect on
Traffic Metter On
speed varies between 32 to 4.
this router is shared by families is a Trailer Resort. The busy times are weekends. The devices vary between iPhone iPad. Android Laptops 1 HP printer 1 alexa & 1 google home
Larry
