Steve2628's avatar
Steve2628
R7000 Armor Security
R7000 — Nighthawk AC1900 Smart WiFi Dual Band Gigabit Router
When I activate Armor Security the router consistently and intermittently fails connecting to the Internet. By disabling Armor Security normal router operations resume. This problem is repeatable every time I reboot the R7000 router.
  • FURRYe38's avatar
    Seen Armor app cause problems before and on other products. Some thing you might contact NG support about and let them know. Not much to troubleshoot if the router works with Armor disabled. Something NG will need to look into.
    Netgear has set up a community forum specifically for the Armor product. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
    https://www.netgear.com/landings/armor
    • Steve2628's avatar
      Steve2628
      Firmware version: 1.0.11.126 and was provided by NG. Factory reset was done with the firmware upgrade.
      Internet router is ATT DDL 45mb.
      Modem System Information
      Type Value
      Manufacturer Pace Plc
      Model 5268AC
      Serial Number 16161N006922
      Hardware Version 260-2173300
      Software Version 11.13.1.533656-att
      Thank you for the quick response and Armor info.
      • FURRYe38's avatar
        What mode is your modem working in? This modem has a built in router already. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
        2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
        3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
