jdwelsh's avatar
jdwelsh
R7000 as a firewall with static ip address
I need to configure my R7000 router as a firewall.  The IP address is a static one.  The modem is a Comcast business modem in bridge mode.  I have set the router with my assigned IP address and their DNS servers.  It doesn't pass the test when I click on it.  My second question would be is their a place in the configuration to assign a gateway for my access from my computers.  One thought I have had but not tried yet is that the address I use to access the configuration page is the gateway.  Is that true.
    By definition, a router is a firewall.  Does this business modem have a brand name and model number?  In general, modems do not have a bridge mode.  Not clear what you mean, doesn't pass the test when you click on it?
    If Comcast business has given you a static IP address, they should have also given you an IP subnet mask and gateway IP address.  Have you tried the configuration where your router to obtains these items dynamically from your ISP?
    When you are making these configuration changes, you should power down (pull the power cord)  for both your modem and router then start them up sequentially with the modem first.  Give the modem time to boot and stabilize before powering up the router.
    • jdwelsh's avatar
      jdwelsh
      Kitsap
      Thanks for the reply.  The "modem" is a Comcast SMC Model SMCD3G and it definitely is in bridge mode.  They made sure I knew when they installed it some years ago.  When I connected it to the modem after having set my IP address, subnet mask, gateway address and their DNS servers, it brought up a browser page that is directed to the netgear site.  It would not connect.
      Inadvertently at the outset I let the R7000 get it's own address, but it still didn't connect to the browser.
      My setup is Comcast modem > R7000 > workgroup network.  Previously I was using a virtual Sophos firewall server through the modem but now I am downsizing from a domain to a workgroup to keep it more simpler.
      I will try the power down/up process tomorrow.
      Thanks!!
      • Kitsap's avatar
        Kitsap
        Master
        jdwelsh wrote:
        Kitsap
        Thanks!!
        That is why I asked for the brand name and model number.  Your device is a combination modem/router with multiple LAN output ports.  Bridge mode is the proper configuration as that disables the router functions.  This device does not appear to have any Wi-Fi capability.  In bridge mode, the only active output port is number 1.  The other ports on the bridged gateway should remain with no connections.
        With no Ethernet connections to the gateway, you should be able to cycle the power and let it boot and stabilize.  One of the LED indicators on the front should indicate internet connection.  With this new configuration you would be best served to do a firmware default reset on your R7000 and configure it from scratch.  With no Ethernet connections to the R7000, power it up and let it boot and stabilize.  On the back is a recessed reset button, use a pen or toothpick to press and hold the button in until the LEDs start to blink.  Release the reset button and let it complete the process.  Now power down your R7000 and connect the WAN port to port 1 on your gateway with an Ethernet cable.  Power up your R7000, let it boot and stabilize.  Using a computer connected to the router with an Ethernet cable, you should be able to connect to the configuration page and complete the configuration process.  If there are any other connection details Comcast business has shared with you, use them in the configuration process.  Like a fixed IP address or a specific type of connection and password.  If you need the manual for the R7000, it can be downloaded here:  https://www.netgear.com/support/
        Any particular reason you are not going to Comcast Business for support assistance in configuring your router?
  • To configure your R7000 router as a firewall with a static IP address, you first need to make sure that the router is connected to the modem and the modem is in bridge mode. Then, you can assign your static IP address and DNS servers in the router's settings.
    However, it seems like you're having trouble with the configuration, and the router isn't passing the test when you try to test it. To troubleshoot this issue, you can check the settings in your router and ensure that you have entered the correct static IP address and DNS servers provided by your ISP.
    Regarding your second question, if you're trying to access the internet from your computers, you'll need to set a default gateway in the router's settings. Typically, this gateway is the IP address of your router, which you can find in the router's configuration page. You can assign this gateway in the network settings of your computer or set it up in the DHCP settings of your router.
    Overall, setting up a firewall with a static IP address can be a bit complicated, and if you're not confident in your technical abilities, you may want to consider hiring a professional to help you with the setup process.
