jdwelsh
Mar 23, 2023Aspirant
R7000 as a firewall with static ip address
I need to configure my R7000 router as a firewall. The IP address is a static one. The modem is a Comcast business modem in bridge mode. I have set the router with my assigned IP address and their...
jdwelsh
Mar 24, 2023Aspirant
Thanks! I will get back to you after I try this. Right now I am temporarily using a Windows server as my firewall but I would feel more comfortable using the R7000. Comcast couldn't/wouldn't help me. Their modem just sits there and doesn't do anything! 🙂
Kitsap
Mar 24, 2023Master
jdwelsh wrote:Thanks! I will get back to you after I try this. Right now I am temporarily using a Windows server as my firewall but I would feel more comfortable using the R7000. Comcast couldn't/wouldn't help me. Their modem just sits there and doesn't do anything! 🙂
Modem is not the most accurate term to use for a gateway configured in bridge mode. Basically your gateway does not do much of anything besides provide a coax connection to the internet on one end and an Ethernet connection to a router on the other.
I presume your Windows server is connecting to the internet through the gateway? If yes, please check to see if the Ethernet connection to the Windows server machine is plugged in to port 1 on the gateway.
- jdwelshMar 29, 2023Aspirant
I have it working now. I had to list Comcast's dns server in the dns settings on the individual computer network connections. Then I had to list the admin ip address as the gateway on each computer. I am a little perplexed by that last setting. I hope that that doesn't compromise security. I can do away with my Windows firewall server now!
