Tmarkreis
Feb 13, 2021Aspirant
R7000 as a WAP
I have just gotten this R7000 wifi router to work alongside my Nighthawk C7000v2 as an Access Point. When I try to follow the instructions in this article... https://kb.netgear.com/24104/How-do-I-c...
Tmarkreis
Feb 14, 2021Aspirant
unfortunately adding http://.... doesn't make any difference, I was just typing 192.168.0.33 into the url window. I even tried using a different browser in case Safari was the issue, just trying anything.
As I had said, I did do a reset on it, is there something else or some other trick to try in the reset process??
Tmarkreis
SOLVED!!!!
I had noticed that it was pumping out a wifi signal, so
I logged onto the wifi with my ipad then went to routerlogin.net which then got me to the genie page for the R7000 and from there i went through all the steps of changing passwords and wifi names and all that jazz. I then moved it to another floor, plugged in the ethernet cable there adn then logged onto a computer using the wifi. So, I mainly had to be on the network of the login I wanted to get into.
When I went into the advanced settings I see that there is a "repeater" mode.... would this be a better option than AP, where it has a different wifi name?? would repeater use the same wifi name as the main router, so I would only have one???
- antinodeFeb 14, 2021Guru
> mode.... [...]Look for "repeater" in the User Manual. Read the fine print:
Note: You cannot use the WPA2-PSK(AES), WPA-PSK(TKIP) +
WPA-PSK(AED) [sic], or WPA/WPA2 Enterprise security modes if you
want to enable this mode. [...]If you want a wireless connection between the main router and the
R7000, and you don't care about wireless security, then that repeater
mode might be useful.
