Paul_R7000
Mar 01, 2017Aspirant
R7000 as router, with Internet from 4G mobile phone hotspot
I have a R7000 router connected to a separate simple ADSL modem.
The problem is that every now and then the landline internet goes down, and I have a complex port forwarding / VPN security set up which takes a while to recreate when I reach for my DC112 ( smart cradle )
I want to keep the R7000 as the central router because it has a strong network signal and powerful processor for internal lan, and I dont want to waste time setting up another router with usb 4G modem/sim chip slot when this happens. ( The Netgear DC112 Smart Cradle is not as powerful as the R7000, even though it does have 4G failover, otherwise I would just use that all the time)
Is there a way to quickly use a 4G mobile phone internet access? I saw a youtube video that did this with a different brand router using WDS bridging and mobile phone hotspot.
Or is there a new router that is more powerful than the R7000 with 4G sim chip failover?
Thanks.
Hi Paul_R7000,
Please check the R7100LG and see if that answers the setup you want.
- JamesGLNETGEAR Employee Retired
Hi Paul_R7000,
- Paul_R7000Aspirant
Yep, thats the right one.
Much easier than fiddling with a mobile phone and bridging the hotspot network to the router network - and its automatic too.
Thanks
