pharbrian
Sep 16, 2021Star
r7000 attached devices list missing connected devices
Many connected devices are missing from the attached devices list in both the router admin page and the android nighthawk app with the 2 most recent firmares 1.011.126 and 1.011.128. Firmware 1.011.1...
- Sep 16, 2021
pharbrian
Sep 16, 2021Star
I'm on the same page as you @FURRYe38. We shouldn't ever be required to factory reset our router after a firmware update to resolve any bugs that are introduced with a firmware update.
Sep 16, 2021Guru - Experienced User
FRs are sometimes a necessary step in troubleshooting and to help validate problems seen. Some "Bugs" may not be bugs at all. There maybe differences introduced in newer FW that can cuase problems when installed over old FW and old user configurations. Thus a reset maybe needed to clear all this out and setup from scratch. Been a long time valid step in using routers. I've seen many issues resolved with a FR. Users choice though and I agree, should be last resort...
If users had working routers before last updates, and don't want to FR, then revert back to FW that was working for you then. You don't always have to have the lastest FW.
Good Luck.
