pharbrian
Sep 16, 2021Star
r7000 attached devices list missing connected devices
Many connected devices are missing from the attached devices list in both the router admin page and the android nighthawk app with the 2 most recent firmares 1.011.126 and 1.011.128. Firmware 1.011.1...
- Sep 16, 2021
pharbrian
Sep 16, 2021Star
Well it looks like a factory reset did the trick. Thanks for the recommendation.
I hope no one else has to do the same. It's a timely ordeal to restore all of your settings. (It took over an hour to restore all of my settings manually.) I did not want to restore my configuration from a save file, as this could have caused my problem to recur.
Sep 16, 2021Guru - Experienced User
Amazing.
Be sure to do a new back up config to file for safe keeping. Saves time if a reset is needed again.
Enjoy. :smileywink:
