clauser
Jan 25, 2017Aspirant
R7000 auto channel selection
I would like to know when the channel selection of the R7000 occurs when set to 'auto'. Does it only happen at startup or does it also happen when the R7000 is up and running?
- Jan 30, 2017
Hi clauser,
It will automatically change once the router detects a channel is being used by different router or if the channel is congested.
JamesGL
Jan 30, 2017NETGEAR Employee Retired
Hi clauser,
JamesGL
Feb 05, 2017NETGEAR Employee Retired
Hi clauser,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- clauserFeb 05, 2017Aspirant
I don't need any further assistance. The answer you gave was very useful.
Thanks for the support.
- JamesGLFeb 08, 2017NETGEAR Employee Retired
Hi clauser.
Thank you for the feedback. We encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
