clauser's avatar
clauser
R7000 auto channel selection
I would like to know when the channel selection of the R7000 occurs when set to 'auto'. Does it only happen at startup or does it also happen when the R7000 is up and running?
  • JamesGL's avatar
    Jan 30, 2017
    Hi clauser,
    It will automatically change once the router detects a channel is being used by different router or if the channel is congested.
