Retired_Member's avatar
Retired_Member
Feb 27, 2016
R7000 BETA 1.0.6.40 ..........SOS..........Different version #
I was somewhat excited to hear that a Beta was being passed around today. 1.0.6.40  So I downloaded and installed it correctly. I entered my settings while off line using a wired connection. The 1st ...
  • Retired_Member's avatar
    Retired_Member
    Feb 27, 2016
    With last Pulled version I had successfully disabled ARLO via arlo setup. Several days later I turn 2.4 off from the advanced wireless settings menu and arlo popped up.
    This time with the latest FW I again successfully turned it off from the arlo setup page and when pushing the front button the main SSID's turned off and arlo popped up.
    I have no interest in testing Jack Squat any further. If and when I need to use the r7000 I'll once again go thru the whole fricken default, reset , powercyle and while facing fricken mecca  install 1.0.4.30 again.
