Retired_Member
Feb 27, 2016R7000 BETA 1.0.6.40 ..........SOS..........Different version #
I was somewhat excited to hear that a Beta was being passed around today. 1.0.6.40 So I downloaded and installed it correctly. I entered my settings while off line using a wired connection. The 1st ...
- Retired_MemberFeb 27, 2016
With last Pulled version I had successfully disabled ARLO via arlo setup. Several days later I turn 2.4 off from the advanced wireless settings menu and arlo popped up.
This time with the latest FW I again successfully turned it off from the arlo setup page and when pushing the front button the main SSID's turned off and arlo popped up.
I have no interest in testing Jack Squat any further. If and when I need to use the r7000 I'll once again go thru the whole fricken default, reset , powercyle and while facing fricken mecca install 1.0.4.30 again.
reply
Mar 05, 2016Guide
Have you guys testing on vpn connection by android device?
I tested the connection is not stable. 1st times is 100% works. But after you reconnect /disconnect no of times. You may not able to connect ot back to home.
My experience is it may allow you to connect it but you may not access intranet / internet.
Other thing is wol function. You guys dont need it? My thinking is wol is home feature. But netgear support told me that is for business/ mote advance router's feature.
After i back to the netgear family. I can conclued that netgear hw is good but their software is too weak.
