Retired_Member
Feb 27, 2016R7000 BETA 1.0.6.40 ..........SOS..........Different version #
I was somewhat excited to hear that a Beta was being passed around today. 1.0.6.40 So I downloaded and installed it correctly. I entered my settings while off line using a wired connection. The 1st ...
- Retired_MemberFeb 27, 2016
With last Pulled version I had successfully disabled ARLO via arlo setup. Several days later I turn 2.4 off from the advanced wireless settings menu and arlo popped up.
This time with the latest FW I again successfully turned it off from the arlo setup page and when pushing the front button the main SSID's turned off and arlo popped up.
I have no interest in testing Jack Squat any further. If and when I need to use the r7000 I'll once again go thru the whole fricken default, reset , powercyle and while facing fricken mecca install 1.0.4.30 again.
SkyOwl
Mar 06, 2016Guide
I always just do an inplace upgrade, no resets, manually reload settings or any of that. You can always fall back to that approach if somethings doesnt work, but its a lot quicker just to upgrade in place. Over the past many years, I've done 200+ firmware upgrades over numerous router brands and only once did I have issues that caused me to go back to the reset, manually reload settings route.
tarund
Mar 06, 2016Apprentice
Thank you, SkyOwl. Appreciate your reply.
- Retired_MemberMar 07, 2016
You can't argue with stupid!
