sir_bazz
Apr 11, 2016Apprentice
R7000 Beta FW 1.0.5.60
Downgrading from Beta 1.0.6.40 to 1.0.5.60, (with Arlo disabled), creates a new nameless SSID.
Mac begins with C6:04:15
Obviously no Arlo settings in 1.0.5.60 so no way disable it
Disabling the 2.4Ghz radio disables the nameless SSID, (as well as the configured SSID), and re-enabling the radio initializes both SSID's again.
Restoring firmware back to 1.0.6.40 and the nameless SSID is no longer visible or available.
- Retired_MemberApr 11, 2016
Did you factory reset after the FW changes. If you didn't the arlo SSID named or non broadcasted SSID could still be present.
After testing and reverting to 4.30 arlo ssid was present when I disabled both 2.4 & 5g until I factory reset a 2nd time.
- Retired_Member
- sir_bazzApprentice
Thanks for the reply searay.
Didn't bother with the reset as it's easier to rollback the firmware than re-enter all the settings again.
I don't think a firmware change should require a factory reset, (or even two as in your case), to remove unintended behaviours.
Was posting as a bug report in the firmware but will flag your reply as the solution for anyone who faces the same issue and wants to resolve it.
- netwrksMaster
sir_bazz wrote:Thanks for the reply searay.
Actually, a very high percentage of router issues identified on this forum, is a direct result of NOT resetting to factory default, after a firmware upgrade. We just don't say it because we don't know what else to tell you. The reason being, it is the only way new drivers etc (or any other additions / deletions) will correctly load, or be deleted. It also removes any firmware and configuration artifacts (stuff that lingers form old to new firmware versions) that can (and really do) cause grief after firmware upgrades. Especially true if you have never reset a router to factory default. Oh, and don't load configs from previous versions of firmware. That's just shooting yourself in the foot.. At least at the end, you are starting with a clean slate on the router. A few minutes of pain, vs. alot of gain..
