sir_bazz
Apr 11, 2016Apprentice
R7000 Beta FW 1.0.5.60
Downgrading from Beta 1.0.6.40 to 1.0.5.60, (with Arlo disabled), creates a new nameless SSID. Mac begins with C6:04:15 Obviously no Arlo settings in 1.0.5.60 so no way disable it Disabli...
- Retired_MemberApr 11, 2016
Did you factory reset after the FW changes. If you didn't the arlo SSID named or non broadcasted SSID could still be present.
After testing and reverting to 4.30 arlo ssid was present when I disabled both 2.4 & 5g until I factory reset a 2nd time.
sir_bazz
Yes of course. No denying it's the big hammer fix for when things don't go quite right with the upgrade process.
Infact IIRC, clearing NVRAM used to be included in the release notes as part of the upgrade process for older firmwares, (for the R7000 anyway).
I recently upgraded from the very old firmware R7000-V1.0.3.61_20140605_QA to 1.0.6.40 and everything just worked without having to clear NVRAM or manually re-enter settings. And that must've involved alot more changes to drivers, settings, secrity fixes, new features, etc than the average upgrader would experience, (R7000 comes default with 1.0.4 now).
On the other hand, I've also installed newer firmwares, (including the supposed stable releases), performed the resets, reconfigured settings from scratch, and still experienced issues at the other end.
The easy fix for me has always been to go back to R7000-V1.0.3.61_20140605_QA and is the reason I've continued to use it for nearly two years now.
Still it's good that access to the big stick, ie. the factory reset, is still available as it does fix alot of config issues that stem from upgrading firmware on this device.
sutedy
Apr 18, 2016Guide
Kindly try these beta firmwares
ftp://download.netgear.com.cn:8084/R7000/
https://drive.google.com/folderview?id=0BwpgHd_U65gNYnpENUNkc1lNS1U&usp=sharing
So far R7000-V1.0.3.49_20140314_ReadyCLOUD and R7000-V1.0.5.60_1.1.86 works well for me
