basehitter10
Aug 16, 2016Initiate
R7000 Block Services not working properly
All, Looking for suggestions here: I have reserved IP addresses for all devices that connect to my router. One particular range (.10 - .16, not that it matters) were set up on a Block Servic...
- Aug 24, 2016
Just as mysteriously, the Srvices Blocking started working as advertised the next night. There was no router reboot that I am aware of. Strange.
storm1985
Aug 16, 2016Prodigy
if you disconnect then reconnect to the network will it work?
if you reboot the router will it work as well?
- basehitter10Aug 24, 2016Initiate
