Max_F
Dec 17, 2016Aspirant
R7000 Bricked after 1.0.7.6_1.1.99 firmware
My R7000 never booted back up after the 1.0.7.6 firmware update that I initiated trough the router web portal yesterday. I thought it was still updating when I didn't get a response after 30 or so mi...
- Dec 21, 2016
Yes finely after a couple of time i fix the problem and the router is working again;)
C:\>tftp -i 192.168.1.1 put R7000-V1.0.7.6_1.1.99.chk
Transfer successful: 27975738 bytes in 25 second(s), 1119029 bytes/sWith the cable it fix the router for me;)
vxd79
vxd79
Dec 18, 2016Aspirant
JUUUUP i want to thanks NETGEAR R7000 for bricked my hawk modem:( after i update it's take soooooo long but after refresh the page it's say your not connected, i reset the modem but it's never work again try to use some tools but no luck for me :( so PEOPLE DON'T upgrade the firmware, it's going to broke your router:(( a very angy person now :(
vxd79
So i try this buy the FTDI TTL-232R-3V3 €32.00 euro cable from internet, hope this wil fix it!! ill let you know wheb i have the cable :)
