Max_F
Dec 17, 2016Aspirant
R7000 Bricked after 1.0.7.6_1.1.99 firmware
My R7000 never booted back up after the 1.0.7.6 firmware update that I initiated trough the router web portal yesterday. I thought it was still updating when I didn't get a response after 30 or so mi...
- Dec 21, 2016
Yes finely after a couple of time i fix the problem and the router is working again;)
C:\>tftp -i 192.168.1.1 put R7000-V1.0.7.6_1.1.99.chk
Transfer successful: 27975738 bytes in 25 second(s), 1119029 bytes/sWith the cable it fix the router for me;)
vxd79
HiSpeed
Dec 18, 2016Guide
Hello Max_F,
Do you mean you bricked the router after an online upgrade?
I upgraded offline, I mean from a firmware file stored on my disk.
May be there is a risk in your case, but I don't know the reasons (bad temp file or other).
I think it is interesting to discuss this point with other users and/or Netgear support...
ElaineM
Dec 19, 2016NETGEAR Employee Retired
Max_F If you can still ping the router, I suggest that you try to follow the steps from this link or try another TFTP client.
However, if you cannot ping the router anymore I suggest that you contact support to get an RMA.
- Max_FDec 20, 2016Aspirant
ElaineM wrote:Max_F If you can still ping the router, I suggest that you try to follow the steps from this link or try another TFTP client.
Thank you for the suggestion Elaine! Yes, I'd tried with multiple. Unfortunately neither tftp, tftp2 nor tftpd64/32 made any difference. Strangest thing is that the router is still pingable and gives a perpetual TTL=100 response so I'm assuming I would need to break the loop with a jtag-cable if I've read the "unbrick your r7000" posts correctly. As I've said before the fix seems easy enough but would void my warranty. I'm waiting for a replacement unit right now but still have the old one sitting ready to be shipped if anyone has any commands they would like me to pass to it in hopes of reviving it.
- ElaineMDec 20, 2016NETGEAR Employee Retired
You're welcome!
- vxd79Dec 20, 2016Aspirant
Thanks for this:) but i try it a couple of times, but never works, i can ping my 192.168.1.10 so it's not broking, i try it with the the cable, i think that will unbrick my R7000;)
- ElaineMDec 21, 2016NETGEAR Employee Retired
vxd79 You're pinging the router, right? If you have tried the suggested steps and won't work then contact support for RMA.
- vxd79Dec 21, 2016Aspirant
Yes i can ping the router:) today i have my TTL-232R-3v3 cable and i mod the cable this way black=ground RX=Yellow TX=Orange put it all together, use Putty on COM6, and this is what i get from the Putty console:
KKKKKKC▒▒02 -------++++++++++++++++++++++++X+++++++++++++++++++++++---------
03 ----++++++++++++++++++++++++X++++++++++++++++++++++++-----------
04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------
05 ------++++++++++++++++++++++++X++++++++++++++++++++++++---------
06 ---+++++++++++++++++++++++X++++++++++++++++++++++---------------
07 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
08 ----+++++++++++++++++++++++X++++++++++++++++++++++--------------
09 ------------+++++++++++++++++++++++X++++++++++++++++++++++------
10 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
11 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
12 ----++++++++++++++++++++++++X+++++++++++++++++++++++------------
13 ----------+-++++++++++++++++++++++X++++++++++++++++++++++-------
14 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
15 -----------+++++++++++++++++++++++X+++++++++++++++++++++++------
PW00000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
01 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
02 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
03 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
04 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
05 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
06 --++++++++++++++++++++++++X+++++++++++++++++++++++--------------
07 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
08 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
09 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
10 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
11 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
12 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
13 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
14 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
15 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
NW00000000000111111111122222222223333333333444444444455555555556666
01 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
02 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
04 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
06 --+++++++++++++++++++++++X+++++++++++++++++++++++---------------
07 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
08 ---++++++++++++++++++++++++X+++++++++++++++++++++++-------------
09 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
10 ------++++++++++++++++++++++++X++++++++++++++++++++++++---------
11 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
12 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
13 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----
14 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
15 -----------++++++++++++++++++++++++X+++++++++++++++++++++++-----
WRDQW00000000000111111111122222222223333333333444444444455555555556666
00 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
01 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
02 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
03 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
04 ++++++++++++++++++++X++++++++++++++++++++-----------+++++++++++-
05 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
06 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
07 ++++++++++++++++++++++++X++++++++++++++++++++++++------++++++++-
08 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
09 -++++++++++++++++++++++++X+++++++++++++++++++++++----------++++-
10 +++++++++++++++++++++++X++++++++++++++++++++++---------++++++++-
11 --+++++++++++++++++++++++X+++++++++++++++++++++++----------++++-
12 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
13 -+++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-
14 ++++++++++++++++++++++++X++++++++++++++++++++++++-------+++++++-
15 -+++++++++++++++++++++++X++++++++++++++++++++++----------++++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR0000000000111111111122222222223333333333444444444455555555556666
00 ++++++++++++++++++S++++++++++++X++++++++++++++++++++++++++++++++Decompressing...done
CFE for Foxconn Router R7000 version: v1.0.21
Build Date: Wed Aug 7 19:11:17 CST 2013
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytesDevice eth0: hwaddr C4-04-15-5B-B8-D8, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Checking crc...Boot program checksum is invalid
Device eth0 has been deactivated.
Start TFTP server
Reading ::I try to Ctrl+C to cancel the program and open the command tftpd now i get Reading::
Now aim going to my CMD with admin rights and use the command:
Connect request failedC:\>
So far wil i come, but he don't want install or upgrade the firmware??
Vxd79
