Max_F
Dec 17, 2016Aspirant
R7000 Bricked after 1.0.7.6_1.1.99 firmware
My R7000 never booted back up after the 1.0.7.6 firmware update that I initiated trough the router web portal yesterday. I thought it was still updating when I didn't get a response after 30 or so mi...
- Dec 21, 2016
Yes finely after a couple of time i fix the problem and the router is working again;)
C:\>tftp -i 192.168.1.1 put R7000-V1.0.7.6_1.1.99.chk
Transfer successful: 27975738 bytes in 25 second(s), 1119029 bytes/sWith the cable it fix the router for me;)
vxd79
vxd79
Dec 21, 2016Aspirant
Yes i can ping the router:) today i have my TTL-232R-3v3 cable and i mod the cable this way black=ground RX=Yellow TX=Orange put it all together, use Putty on COM6, and this is what i get from the Putty console:
KKKKKKC▒▒02 -------++++++++++++++++++++++++X+++++++++++++++++++++++---------
03 ----++++++++++++++++++++++++X++++++++++++++++++++++++-----------
04 --++++++++++++++++++++++++X++++++++++++++++++++++++-------------
05 ------++++++++++++++++++++++++X++++++++++++++++++++++++---------
06 ---+++++++++++++++++++++++X++++++++++++++++++++++---------------
07 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
08 ----+++++++++++++++++++++++X++++++++++++++++++++++--------------
09 ------------+++++++++++++++++++++++X++++++++++++++++++++++------
10 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
11 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
12 ----++++++++++++++++++++++++X+++++++++++++++++++++++------------
13 ----------+-++++++++++++++++++++++X++++++++++++++++++++++-------
14 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
15 -----------+++++++++++++++++++++++X+++++++++++++++++++++++------
PW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
01 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
02 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
03 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
04 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
05 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
06 --++++++++++++++++++++++++X+++++++++++++++++++++++--------------
07 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
08 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
09 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
10 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
11 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
12 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
13 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
14 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
15 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
NW0
01 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
02 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
04 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
06 --+++++++++++++++++++++++X+++++++++++++++++++++++---------------
07 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
08 ---++++++++++++++++++++++++X+++++++++++++++++++++++-------------
09 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
10 ------++++++++++++++++++++++++X++++++++++++++++++++++++---------
11 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
12 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
13 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----
14 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
15 -----------++++++++++++++++++++++++X+++++++++++++++++++++++-----
WRDQW0
00 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
01 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
02 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
03 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
04 ++++++++++++++++++++X++++++++++++++++++++-----------+++++++++++-
05 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
06 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
07 ++++++++++++++++++++++++X++++++++++++++++++++++++------++++++++-
08 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
09 -++++++++++++++++++++++++X+++++++++++++++++++++++----------++++-
10 +++++++++++++++++++++++X++++++++++++++++++++++---------++++++++-
11 --+++++++++++++++++++++++X+++++++++++++++++++++++----------++++-
12 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
13 -+++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-
14 ++++++++++++++++++++++++X++++++++++++++++++++++++-------+++++++-
15 -+++++++++++++++++++++++X++++++++++++++++++++++----------++++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
00 ++++++++++++++++++S++++++++++++X++++++++++++++++++++++++++++++++
Decompressing...done
CFE for Foxconn Router R7000 version: v1.0.21
Build Date: Wed Aug 7 19:11:17 CST 2013
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0: hwaddr C4-04-15-5B-B8-D8, ipaddr 192.168.1.1, mask 255.255.255.0
gateway not set, nameserver not set
Checking crc...Boot program checksum is invalid
Device eth0 has been deactivated.
Start TFTP server
Reading ::
I try to Ctrl+C to cancel the program and open the command tftpd now i get Reading::
Now aim going to my CMD with admin rights and use the command:
Connect request failed
C:\>
So far wil i come, but he don't want install or upgrade the firmware??
Vxd79
vxd79
vxd79
