CCNE37's avatar
CCNE37
Luminary
Oct 09, 2019
R7000 bricked after firmware update attempt
I have recently tried a firmware upgrade on my R7000, and it never got past the dreaded white blinking power light.   I found other threads that referred to the tftp process, and tried a few things...
  • CCNE37's avatar
    CCNE37
    Oct 09, 2019
    Thanks again.
    Well I tried again from scratch, and got something to happen using the Windows 10 TFTP client.
    It came up with a message saying that transfer was successful.
    After a few minutes, the power light turned solid orange and stayed orange for about 10 minutes - I was about to pull everything apart again, when it suddenly turned solid white and the internet light came on.
    I have checked and the firmware is back where it was before I believe, which is the same as the firmware version I used for the transfer via TFTP.
    I am very hesitant to try the firmware update again.
    Thanks you for your help :smileyhappy:  Much appreciated.
    Colin
