Bart83
Mar 26, 2019Aspirant
r7000 bricked after update
Hello,
While updating the firmware to the latest version. The router stopped responding and now I am unable to access it or reload firmware. The power button is white and flashing. What can i do? u...
- Mar 27, 2019
Thank you, He is working:D
jbae843123
I'm sorry to hear that...
I updated to version 64 a couple of weeks ago, and I noticed many issues, but it did not brick my router.
When I just checked the release note of version 64, it had "Last modified" of 3/26/2019, instead of 1/??/2019.
Maybe they re-released the firmware under the same version number, and it was a bad one?
To fix the issue, try factory reset? or check this link out.
I hope everything works out
Bart83
Mar 27, 2019Aspirant
- michaelkenwardMar 27, 2019Guru - Experienced User
A more recent explanation of the process is here:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
