Bart83
Mar 26, 2019Aspirant
r7000 bricked after update
Hello,
While updating the firmware to the latest version. The router stopped responding and now I am unable to access it or reload firmware. The power button is white and flashing. What can i do? u...
- Mar 27, 2019
Thank you, He is working:D
buster_petaluma
Mar 27, 2019Aspirant
Got an email recommending update. I used the Netgear App to update. Click, Download,Install. Easy. But, the power light blinked constantly white. waited 35 minutes for the hair-ball to clear. Didn't. All devices are dark. No internet, ROUTER BRICKED. Mac OSX environment.
Tried every idea I had, tried ideas online and here (had to use my phone).
Had to go buy a new router (imperiative that I get back in business now). Not happy having to replace my 2 yr old R7000. Hopefully the new AC3000P lasts longer.
- antinodeMar 27, 2019Guru
> [...] Tried every idea I had, tried ideas online and here (had to use
> my phone). [...]Think for a moment about how little useful unformation that
non-description conveys to the non-psychics in your audience.> [...] But, the power light blinked constantly white. [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:https://community.netgear.com/t5/x/x/m-p/1622096
> [...] waited 35 minutes [...]
I wouldn't expect time to cure a flashing power indicator.
The Mac-specific details are covered in that cited thread (and links
therefrom).> Had to go buy a new router [...]
Rehabilitating the old one as a spare might be useful someday, then.
- buster_petalumaMar 30, 2019Aspirant
Rehabilitating the dead R7000 is not possible. It will not communicate with my devices/computers.
It does not even send out a network signal - it can not be "seen". It does not show up in Networks list. It is just dead/bricked.
Hope no one else experiences this.
- michaelkenwardMar 30, 2019Guru - Experienced User
I see no evidence in your messages that you are following the correct procedure for TFTP.
What is this "network signal" that you expect to see?
No, it won't show up in a Networks list, whatever that means. The fact that you are even looking there suggests that you are not following the instructions:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Go through things slowly, one a step at a time and tell people where it isn't working for you and what error messages you see.
You might also do better to start a new discussion rather than hitching a ride on the end of one started by someone who has fixed their problem. They have marked this is SOLVED so it is unlikely that anyone from Netgear will see your message. They are too busy firefighting new challenges.
