Bart83
Mar 26, 2019Aspirant
r7000 bricked after update
Hello,
While updating the firmware to the latest version. The router stopped responding and now I am unable to access it or reload firmware. The power button is white and flashing. What can i do? u...
- Mar 27, 2019
Thank you, He is working:D
antinode
Mar 27, 2019Guru
> [...] Tried every idea I had, tried ideas online and here (had to use
> my phone). [...]
Think for a moment about how little useful unformation that
non-description conveys to the non-psychics in your audience.
> [...] But, the power light blinked constantly white. [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:
https://community.netgear.com/t5/x/x/m-p/1622096
> [...] waited 35 minutes [...]
I wouldn't expect time to cure a flashing power indicator.
> Mac OSX environment.
The Mac-specific details are covered in that cited thread (and links
therefrom).
> Had to go buy a new router [...]
Rehabilitating the old one as a spare might be useful someday, then.
buster_petaluma
Mar 30, 2019Aspirant
Rehabilitating the dead R7000 is not possible. It will not communicate with my devices/computers.
It does not even send out a network signal - it can not be "seen". It does not show up in Networks list. It is just dead/bricked.
Hope no one else experiences this.
- michaelkenwardMar 30, 2019Guru - Experienced User
I see no evidence in your messages that you are following the correct procedure for TFTP.
What is this "network signal" that you expect to see?
No, it won't show up in a Networks list, whatever that means. The fact that you are even looking there suggests that you are not following the instructions:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
Go through things slowly, one a step at a time and tell people where it isn't working for you and what error messages you see.
You might also do better to start a new discussion rather than hitching a ride on the end of one started by someone who has fixed their problem. They have marked this is SOLVED so it is unlikely that anyone from Netgear will see your message. They are too busy firefighting new challenges.
- antinodeMar 30, 2019Guru
> Rehabilitating the dead R7000 is not possible. [...]
"I couldn't do it, so it's impossible."
I'd guess that ranting in multiple old threads won't help much more
than ranting in one old thread.> Hope no one else experiences this.
I agree. Trying to deal with a completely useless problem
description (scattered across multiple threads) certainly _is_ trying.- buster_petalumaApr 06, 2019Aspirant
Thanks for the snarky response. Not helpful, at all
- antinodeApr 06, 2019Guru
> Thanks for the snarky response. [...]
You're welcome.
> [...] Not helpful, at all
So, just like "Tried every idea I had" and "is not possible", then?
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations. Or repetitive, broadcast rants.
