NWWA's avatar
NWWA
Tutor
Feb 03, 2018
R7000 bricked during firmware update to 1.0.9.18
While updating the firmware to the latest version (1.0.9.18). The router stopped responding and now I am unable to access it or reload firmware. The power button is white and flashing. I have tried t...
  • NWWA's avatar
    Feb 04, 2018
    I have successfully recovered my router, with the help of an old post by ghoffman (along with many other): under the thread "[SOLVED] Steps for debrick unresponsive R7000 (softbricked)"
    The steps as written:
    5.confirm the cfe is waiting for firmware by 'ping 192.168.1.1' a 'ttl=100' response is what you are looking for
    6. use 'tftp -i 192.168.1.1 put factory.trx' to upload you newly created image
    7. wait 2-3 minute for a couple reboots.
    This is how I implemented these steps:
    1. Open the command window and change the directory to my desktop (this is where the dowloaded firmware is located)
    2. Type the command: ping 192.168.1.1 a ttl=100
    3. Open a second command window and type: tftp -i 192.168.1.1 put 1.0.9.18.chk
    4. Turn on the router (no need to hold reset button).
    5. Start the ping comand in the first window.
    6. When the ttl response = 100, start the tftp command in the second window.
    7. This took a few minutes. When it is complete the router reset.
    There are many other steps that are needed to get to this point, but these are the critical steps that I needed to get my pc to connect to the router and load the firmware.
    Thank you for all the responses.
