Jay2x
Jun 23, 2019Aspirant
R7000 bricked during update cannot recover.
I recently tried to upgrade the firmware and power went off. My router is responsive coz I followed https://kb.netgear.com/27477/How-to-resolve-amber-LEDs-or-a-blinking-power-LED-on-NETGEAR-routers ...
- Jun 24, 2019
First, find out how to do copy+paste from a Command Prompt window, or
else how to do a screen grab on Windows. Your photo cropped off the
useful part of the file name.> [...] But after it says "transfer successful: 224 bytes in second(s),
> 224 bytes/s" nothing happens to the router it just keeps power blinking
> led.What I see is, "Transfer successful: 224 bytes in 1 second(s), 224
bytes/s". But you were close.To me, that looks like the TFTP scheme is working, but 224 bytes is
not even close to the size of a firmware image file. For a popular
recent version, for example:pro3$ unzip -l R7000-V1.0.9.42_10.2.44.zip Archive: R7000-V1.0.9.42_10.2.44.zip Length Date Time Name --------- ---------- ----- ---- 32268346 09-10-2018 13:31 R7000-V1.0.9.42_10.2.44.chk 3121 10-01-2018 12:26 R7000-V1.0.9.42_10.2.44_Release_Notes.html --------- ------- 32271467 2 filesSo, a typical correct file ("R7000-V1.0.9.42_10.2.44.chk") has a size
of roughly 32MB (not 0.2KB). I don't know what you sent to the router,
but it seems to have been some small, wrong thing, not the appropriate
".chk" file.
> This is the version that I'm trying to reinstall,
> R7000-V1.0.8.34_1.2.15 [...]Why?
> [...] I'm not sure if it can revert to any old firmware. [...]
I'd expect loading any version to be possible, if you can load some
version.> [...] I really feel that this is a trash unit, [...]
Perhaps, but so far there's little evidence that you're trying to
push a real firmware image file at it.
microchip8
Jun 23, 2019Master
Have you followed this article? https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
antinode
Jun 23, 2019Guru
> [...] I tried to fix it with firmware but doesn't work. I used the
> method tftp2 and cmd method nothing seems to work. [...]
"tried" or "nothing seems to work" is not a useful problem
description. It does not say what you did. It does not say what
happened when you did it. As usual, showing actual actions with their
actual results (error messages, LED indicators, ...) can be more helpful
than vague descriptions or interpretations.
> [...] I always get the "unable to get responses from the server."
From what? When you do what, exactly?
The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error.
There's no need to download any third-party TFTP client program
("tftp2"). On which computer operating system are you trying to do
this?
