DLMSU's avatar
DLMSU
R7000 bricked, serial won't recover it
So I had a working R7000 that was several firmwares old, tried to use the web portal to update to the newest 1.0.9.12.
Router went to restart, bricked.  Every 30 seconds or so the router restarts.  Tried the TFTP method at boot, it wouldn't take.  So I bought a USB TTL cable, and opened it up.  Was able to get new firmware flashed.  Tried reflashing same firmware.  Bricked.  Flashed a few versions older.  Bricked.  Flashed one of the first firmware releases.  Still bricked.
Tried holding the factory reset after each flash on a bootup, just in case.
Any Idea on what to do next?  I really wanted to try the Circle stuff, and was going to move this router to be my main router for a while, since I have small children and it is about that time.
  • If you can gain access to the routers main board you may be able to run a nvram clear command and reflash the router's firmware, if that will not happy the router may have a hardware issue.
    What the cause the router to be bricked in the first place?
    • DLMSU's avatar
      DLMSU
      Tried to firmware update it via the GUI. No shenanigans. Somehow it just corrupted itself.
      • William10a's avatar
        William10a
        Master
        Have you a terminal program to view the processes of the booting process.
    • DLMSU's avatar
      DLMSU
      Thanks so much.  Clearing the nvram and then reflashing it fixed it.
