iochoa2
Dec 01, 2015Aspirant
R7000 Can not download firmware 1.0.5.48
I tried to download the firmware from the support site, but I got a trunkate file, with just 3 MB size, I could download the previous firmware, but the in the new release I got this problem, anyone t...
- Dec 01, 2015
Thanks, It was magic, I tried that several times, this time works!!
Thanks.
Babylon5
Dec 01, 2015NETGEAR Employee Retired
Following the ‘Download’ link at the top of this page I was able to download the firmware you refer to, have you tried using a different computer / smartphone etc.?
DanT2590
Dec 01, 2015Tutor
I've tried for a week and can't get 1.0.5.48_1.1.79 to download.
I also tried downloading the zip file, but when I went to unzip, it says not a valid format.
I would really like to upgrade since my version is getting pretty old since I flashed the memory.
What else can I try????
- Babylon5Dec 02, 2015NETGEAR Employee Retired
Have you tried downloading using other PCs?
I'm actually having trouble accessing the 'Downloads' page right now, I'm at work but even so can normally access it here, so I'm guessing that there may be server-side issues. If this is still the case at the end of today I will contact Netgear (or another moderator might check in the mean-time).
- DanT2590Dec 02, 2015Tutor
Yes, I've tried using 3 computers here in the house. All of them do the same thing. The zip file won't unzip and says its corrupt!
- iochoa2Dec 02, 2015Aspirant
Hi.
What work for me is in the download page when the popup said to register again, I enter ALL THE DATA with the Router SN and click register and download.
That was the only valid way to get a valid file.
Hope this work for you.
