xbeaus
Sep 20, 2019Aspirant
R7000 can not login to router
Bought it used. WiFi works but I can not login to routerlogin.net. can't reset password either. Continue is greyed out. I have tried factory reset twice. 30-30-30 reset. On my old router (older Netgea...
- Sep 20, 2019
xbeaus wrote:
The Modem I just purchased is a Netgear CM700.
That's good, a basic cable modem. No built-in router to complicate things.
xbeaus wrote:
Investigating online shows that they are in fact newer on the market.
If you mean the R7000P, don't worry. What you have is fine. Unless you have fancy needs, it should do what you want.
xbeaus wrote:
Anyway - I asked the guy if he ever changed the IP address of the router and he wasn't aware that he did. It sat on a shelf for most of it's life according to the guy.
If it is second hand, there is a good chance that the router has some settings in there from the original owner.
I doubt if they bothered to clear those out, so it is a good idea to do a factory reset on the thing and set it up from scratch.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
Don't worry, it isn't complicated, and I doubt if you will have done much to tweak it for your needs. And you already know how to set it up. You've done it already.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
xbeaus
Sep 21, 2019Aspirant
All good! I was able to reset it and back in factory settings!
