leohuang123
May 04, 2021Tutor
R7000 can only us firmware V1.0.9.6 and old. newer firmware will brick the router.
Hi, I bought two R7000 at same time several years ago. At very begining they ware working well and I had no problem upgrading to the newer firmware until v1.0.9.6. After I upgraded both routers I ...
May 05, 2021Guru - Experienced User
Its been a constant debate on here as to why a lot of the r7000's function fine on newer firmware and others have issues with the newer versions. There has never been an official reason why.
some people have had quite good success using 3rd party firmware with the r7000. Ever tried any with the one that won't upgrade?
leohuang123
May 05, 2021Tutor
plemans wrote:Its been a constant debate on here as to why a lot of the r7000's function fine on newer firmware and others have issues with the newer versions. There has never been an official reason why.
I tried freshtomato but no luck. Even could not recover it using tftp. Had to open the back cover and restored the orginal firmware using JTAG.
- plemansMay 05, 2021Guru - Experienced User
If you're installing using JTAG, you're in advance of most people on here.
