Hohokam337
May 25, 2016Aspirant
R7000 Cannot connect some devices to Wireless. ("Obtaining IP address..")
I got this router maybe 4 months ago after a large storm that took out my previous router (Netgear WNDR4000) and the internet cable. Ever since I installed the new router I cannot connect to the wire...
- May 28, 2016
I figured it out, but it makes no sense..
I noticed that I have two wired connections to the router, one being my PC and another to my alarm system, AT&T Digital life. I noticed that it was acquiring two wired connections positions in the Genie when it was plugged into only one slot? Also the light was orange on the router, where it was plugged into. I unplugged it and the wireless works perfectly on all the devices..
Can anyone explain this?
Also thank you for everyone's help!!
Hohokam337
May 27, 2016Aspirant
Yes but all new devices are allowed. I changed it to off even , still same problem
TheEther
May 27, 2016Guru
Do you see anything in the R7000 logs? Did you reboot after disabling access control?
- IrvSpMay 28, 2016Master
If you DISABLE security do they connect?
- Hohokam337May 28, 2016Aspirant
