jktstance's avatar
jktstance
R7000 Cannot connect to device through ethernet
Hi all, I've had this R7000 router for a year now when suddenly it lost its internet connection. After doing the obligatory power cycles on the modem and router, nothing. I could login to the router ...
  • jktstance's avatar
    Jun 05, 2021
    Solved.
    I don't know how it's solved. After the 10th time of trying to connect to the router's wifi, I was able to get the Nighthawk app to start working and setup. I have no clue what happened, but the only lights on for the router were power (in red) and the two devices I had connected to the LAN ports.
