gpetroski
Jun 11, 2016Initiate
R7000 can't access admin page anymore and DHCP IP Range changed on its own
I noticed recently that my internal IP range changed from 192.168.1.* to 10.0.1.* on its own. I believe I had the router configured to auto update to new firmware, so I'm guessing it updated itself a...
- Jun 12, 2016
I was able to determine the cause. It tipped me off when you said the IP range changes when there's a second device doing DHCP. I noticed there were new computers on my network when I looked at network file sharing. I use the Netgear Powerline device to get wired connections to my living room. What I believe happened is that my neighboring apartment unit recently set up internet and is also using a powerline device. I noticed my DNS suffix was changing to a different address which is the ISPs instead of my router. I put 2 and 2 together and realized my network was overlapping with his via the powerline. I never set up an encryption key on the powerline so it was still using default settings and connecting to my neighbors powerline. When I added the encryption key, the problem went away and my network returned to normal. Next time I should follow the instructions when setting up new network hardware. Oops
VE6CGX
Jun 11, 2016Master
Show us your network layout. You only have one modem, one router or anything else? Hard to believe what happened to your R7000.
