gpetroski
Jun 11, 2016Initiate
R7000 can't access admin page anymore and DHCP IP Range changed on its own
I noticed recently that my internal IP range changed from 192.168.1.* to 10.0.1.* on its own. I believe I had the router configured to auto update to new firmware, so I'm guessing it updated itself a...
- Jun 12, 2016
I was able to determine the cause. It tipped me off when you said the IP range changes when there's a second device doing DHCP. I noticed there were new computers on my network when I looked at network file sharing. I use the Netgear Powerline device to get wired connections to my living room. What I believe happened is that my neighboring apartment unit recently set up internet and is also using a powerline device. I noticed my DNS suffix was changing to a different address which is the ISPs instead of my router. I put 2 and 2 together and realized my network was overlapping with his via the powerline. I never set up an encryption key on the powerline so it was still using default settings and connecting to my neighbors powerline. When I added the encryption key, the problem went away and my network returned to normal. Next time I should follow the instructions when setting up new network hardware. Oops
IrvSp
Jun 11, 2016Master
What does IPCONFIG /ALL show from a connected Windows PC in a COMMAND prompt?
Usually it would rotate through specific internal LAN IP Addresses IF it found when turning on other Private IP xxx.xxx.xxx.1 is active on the LAN it is attached too, namely your modem? However the ISP would need to do that change.
Did you try 10.0.0.1 or 192.168.0.1?
The other possibility is you have set a device on your LAN to have 192.168.1.1 as its IP Address (printer for instance). Of course you couldn't connect that device if you did, but once the router updated and rebooted it would see that and switch. So check all devices and make sure it isn't trying to use that address.
- VE6CGXJun 11, 2016Master
How a gateway address can be assigned to a device? DHCP is not that dumb!
- IrvSpJun 11, 2016Master
All you need do is set it to be that. Printer's can be easily, and can almost and network card. Nothing stops you from setting the router to a different IP Address within the private network too as the gateway. Go to ADVANCED --> SETUP --> WAN SETTINGS and you can change the DEFAULT of 192.168.1.1. Useful when more than 1 router is in a network. Easy to mess up and have a collision with other devices.
Useful ip address starts from 192.168.1.2 is it not? You mean you can clobber the gateway address at will or by accident? Mever saw it
happening.
