Cmnessler
Nov 27, 2018Aspirant
R7000 cant access my security cameras
I have 2 security cameras installed on my network, but I am unable to access the feed on my phone when my phone is not on the same network. I have been informed by the camera company that this is hap...
- Nov 28, 2018I hope you have a great day antinode. I shall take my ignorance and stupidity elsewhere.
Cmnessler
There is no need to be so passive aggressive - it helps no one.
The type of security camera is irrelivent. I am only looking for a step by step guide to disabling the firewall so I can view these cameras when I am away from my home network, which these cameras are connected to. I have been ‘searching’ for this step by step guide online. I view the camera feeds through an app.
antinode
Nov 27, 2018Guru
Passive? There is no need to be so stingy with useful (or required)
information, either. If you insist on treating simple, relevant
questions as intrusive or unimportant, then it'll be very tough to make
any progress.
> The type of security camera is irrelivent. [...]
And you know this how, exactly? If you could distinguish between
relevant and irrelevant in this context, then you likely wouldn't be
here asking (information-free) questions like this. (And wearing out
your welcome with someone who might be able to help, if given a chance.)
> [...] I am only looking for a step by step guide [...]
Please let us know if you find one.
> [...] to disabling the firewall so I can view these cameras when I am
That's not how it works. You have a NAT router; the "firewall" is
implicit in its operation. You can configure (port forwarding on) the
router to allow incoming connections to any device(s) on your LAN.
Sadly, however, that requires some actual information about which
external ports to forward to which internal ports at which IP addresses.
That is, actual information about how your (unspecified) cameras work.
> [...] I view the camera feeds through an app.
I wouldn't want you to wear yourself out with exhaustive detail, but
it might help to know how this (unspecified) app identifies/locates a
particular camera.
- CmnesslerNov 27, 2018AspirantThanks for your input. I was only looking for help - not a lecture. If you have nothing more productive to add, I will look for another individual to help me. Thank you and have a fabulous night.
- antinodeNov 27, 2018Guru
> [...] I was only looking for help - not a lecture. [...]
Ok, but you seem not to understand the problem. Hence my attempt at
education, hopeless as it may have been.
> [...] If you have nothing more productive to add, [...]
Without any useful information, there's little that I can do.
> [...] I will look for another individual to help me. [...]
I wish you the best of luck in your search for a psychic with IP
networking knowledge.
My car won't run. I have been informed by the car dealer that my
filters are defective, but I can't find them. I have been searching for
an answer and have come up empty. The make and model of the vehicle are
irrelevant, and I won't answer any other questions. Please help me.
With that attitude, you may need more than luck and "another
individual".
