bfuccillo's avatar
bfuccillo
Follower
Nov 27, 2022
R7000 cant connect to gaming servers
Was having some intermittent connection issues with my ISP, and in their efforts to remotely diagnose/resolve the problem, something happened to my router...I can no longer connect to gaming servers.  The ISP cant figure out what they did or provide any help resolving it since its not their router.  If I bypass the router and connect directly to the modem, there is no problem, so it has to be on the router side?  The game server IT had me install Cloudflare WARP as a sort of VPN I guess, which does allow me to connect, but with much lower speeds than I would have direct.  I've checked the firmware and rebooted the router many times, any ideas what I can do?
1 Reply
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Are you wireless or wire connected to the router?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
