psychotic_satyr
Jan 15, 2017Aspirant
r7000 can't connect to webinterface
I had my stuff all working, r7000 as an AP to my FIOS network, r7000 was the wireless point. everything was fine. I hit the auto connect button by mistake and it jacked everything up. so i res...
- Jan 23, 2017
yes, checking the list of things in the fios interface I was able to find the r7000 and login to it so I could set it as I wanted. I am not sure how it got connected since it wasn't in the DHCP pool, but I found it like you said.
Thank you for your assistance.
QM
JamesGL
Jan 19, 2017NETGEAR Employee Retired
Hi psychotic_satyr,
If the R7000 is set to AP mode, you have the option to set static or dynamic. If it is on dynamic, check the FIOS router for the IP address of the R7000.
- psychotic_satyrJan 23, 2017Aspirant
QM
