psychotic_satyr's avatar
Jan 15, 2017
r7000 can't connect to webinterface
I had my stuff all working, r7000 as an AP to my FIOS network, r7000 was the wireless point. everything was fine. I hit the auto connect button by mistake and it jacked everything up.     so i res...
  • psychotic_satyr's avatar
    psychotic_satyr
    Jan 23, 2017
    yes, checking the list of things in the fios interface I was able to find the r7000 and login to it so I could set it as I wanted. I am not sure how it got connected since it wasn't in the DHCP pool, but I found it like you said.
    Thank you for your assistance.
    QM
