EMF
Sep 10, 2017Aspirant
R7000 capped at 100Mbps
I should be getting 400/40 from my ISP but am only getting 100/10. If I hardwire directly into my cable modem (Netgear CM500) I can get the 400/40. As soon as I go through the router (using the same ...
- Sep 10, 2017
Possible the qos set up of the router is what the problem is.
William10a
Sep 10, 2017Master
EMF
Sep 11, 2017Aspirant
I'm not 100% sure what fixed it, but what I THINK I did was turn QoS off, click 'apply' (which says it reboots the router but maybe is just a soft reset?), but then manually reboot the router for it to really take effect. Until I manually told my router to reset, turning off QoS and clicking apply still didn't work. Thanks for the help!
