tucsontico
Sep 12, 2015Virtuoso
R7000 Connectivity Issues
My R7000 router had been working fine until the last few days. I began to get intermittent dropouts from the internet. They mostly appear as failures to load thumbnail pictures in emails, eBay, not p...
- Sep 16, 2015
I swapped out the suspect Cat5E for a shielded Cat 6 cable yesterday afternoon. After 12 hours, the LAN connection to my wife's iMac appears to be stable. She is getting proper email downloads and web page renderings. I don't want to jinx it, but I'd say the problem is solved–for now!
I truly believe the router was at fault initially because both of my hard-wired iMacs were sufffering similar download/rendering problems. After performing a reset to factory defaults and a re-install of firmware, the LAN was more stable. Switching to a different DNS appears to have helped the stability and speed. I also believe the biggest problem was the Cat 5E cable to my wife's iMac.
Lesson learned (again!): Always check the cables first!
tpl
Sep 21, 2015Aspirant
9.21.2015
I had the same problems as the original poster, but I solved it differently.
Comcast verified my Internet connection was good. But 5 GHz was not loading videos and often dropped web pages.
I was using 4.30 firmware, the latest version. But I learned in another thread on this topic that 4.30 is causing problems.
So I uploaded 4.28 firmware and then reinstalled the factory settings. INSTANT FIX. I do hope Netgear reads this and gets to work on whatever is wrong with 4.30.
- tucsonticoSep 25, 2015Virtuoso
My issues were not with the WiFi signal. The problems occured only with ethernet connection. It appears to be solved after reseting the router, re-installing the firmware and replacing a bad CAt 5e cable.
- willipOct 14, 2015Aspirant
I am having a similar issue recently. I am using the R7000 and it is updated to the latest firmware.
I had a strong wifi signal but suddenly I am not able to connect to internet. The modem side is working fine as I do have Internet TV and I am pretty sure that it is connected.
The R7000 admin page also stated that the Internet connection is "Good" but I am totally disconnected.
The problem will go away after I reboot the R7000 and it will re-surface again in a day.
Any others face the same and any solutions proposed?
- DexterJBOct 14, 2015NETGEAR Moderator
Hi willip,
Have you tried performing a firmware re-flash then reset and reconfigure the router? If not yet, you may refer to the links below for the steps:
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
