csilva
Dec 31, 2020Aspirant
R7000 Current Firmware
Received Netgear security email to update firmware. Using the mobile app, it says that there is no update needed. According to the app, the current firmware version is 1.0.9.88_10.2.88 which is not...
microchip8
Dec 31, 2020Master
Do not use crappy apps for firmware updates, unless you want a bricked router
Ditto for WiFi
Use a wired connection to the router at http://192.168.1.1
You can get the latest frimware from: https://www.netgear.com/support/product/r7000.aspx
For the R7000P it's https://www.netgear.com/support/product/R7000P.aspx
You talk about the R7000 but have listed the R7000P in your model field. Which is it?
- CbrickeyDec 31, 2020Aspirant
I'm not sure where the 'P' came from. I actually did exactly what you said (used my desktop) but I didn't have links-just searched until I found the update. I downloaded it, then uploaded it and the router supposedly rebooted, etc. However, after all that, I still have the same firmware version I had before. Do I have to be paying for support for updates to work?
- plemansDec 31, 2020Guru - Experienced User
No. did you follow the manual update process? did it error out?
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
