csilva
Dec 31, 2020Aspirant
R7000 Current Firmware
Received Netgear security email to update firmware. Using the mobile app, it says that there is no update needed. According to the app, the current firmware version is 1.0.9.88_10.2.88 which is not...
Dec 31, 2020Guru - Experienced User
If you have the R7000, there is newer firmware. (you put r7000 in the title but r7000P in the signature).
you can get it here and manually install it.
Nighthawk R7000 | AC1900 Smart WiFi Router | NETGEAR Support
I'd try that first, do a factory reset and clean install afterwards (Not from backup) for best results.
csilva
Jan 02, 2021Aspirant
Excuse the "P". It was accidentally entered.
