SpudLord
Feb 05, 2020Guide
R7000 Cutting my download speed in half.
So recently my R7000 router has been cutting my download speed I half. When I run a speed test through my modem I'm getting around 380-415Mbps but when I run a speed test through my R7000 I'm getting ...
- Feb 06, 2020
SpudLord wrote:
michaelkenward So to do all of this I just need to make sure I have logged into my router by going to 192.168.1.1 in a web browser then disconnect from the modem. Also I have to have the .42 firmware saved somewhere like my desktop then followe the steps?If you can login to that address, you've got it.
Indeed, if you can login, you don't even need to disconnect the modem.
Keep a copy of the firmware somewhere convenient. Remember, it arrives as a zip file and you'll need to unzip it before the router will accept it. Those instructions should be in the release notes, which are also on the zip file.
SpudLord
Feb 06, 2020Guide
michaelkenward So to do all of this I just need to make sure I have logged into my router by going to 192.168.1.1 in a web browser then disconnect from the modem. Also I have to have the .42 firmware saved somewhere like my desktop then followe the steps? Sorry I'm really bad when it comes to networking so having to explain it like talking to a 5 year old is the only way I'm going to understand.
michaelkenward
Feb 06, 2020Guru - Experienced User
- SpudLordFeb 06, 2020GuideThe only other thing that is confusing still is how to disable the automatic update after I reset it because don't I need to set the router up again before I can configure the settings. Also I use the nighthawk app to set my router up so there is that to take I account too.
- SpudLordFeb 06, 2020Guidemichaelkenward The only other thing that is confusing still is how to disable the automatic update after I reset it because don't I need to set the router up again before I can configure the settings. Also I use the nighthawk app to set my router up so there is that to take I account too.
I did what you have said and it did nothing. My Download speed is still being cut in half. - SpudLordFeb 06, 2020Guidemichaelkenward plemans I stand corrected it seem it might be better it's not perfect but I think it will do for now. Thank you for your time and teaching me how to do what needed to be done I really appreciate it.
