harrma
Jul 27, 2021Aspirant
R7000 default gateway missing
Whenever I try to use this router I get ip adress incorectly cinfigerd and when I do ip config /all the defalt gateway is missing and factory reset didn't work nor did these: https://validedge.com/e...
harrma
the first one said it falled to connect to target and the seccound says (firmware) file not recognized
Jul 27, 2021Guru - Experienced User
tftp can take a few tries as its sensitive to timings.
Make sure to watch the video.
Also, ensure you're using the correct firmware
