InterociterOper's avatar
Jan 02, 2021
R7000 Devices Website shows no firmware update needed....
I got a notice my firmware for my R7000 needed an update, but checking with my devices webpage, it says there is no update available, even though I am running 1.0.9.... Firmware Version V1.0.9.88_1...
  • Portwey84's avatar
    Jan 02, 2021
    isn
    Firmware Version
    V1.0.9.88_10.2.88
    How do I get this fixed?
    I don't want to put another #$%# app on my phone.
    Also, the firmware update zip file I downloaded shows "shard" files?????  Is that right?
    If I brick this thing there will be no end of "heck" to pay.
    InterociterOper
    Your device is 3 firmware upgrades behind going by the firmware update you have referenced. The latest firmware is:
    https://kb.netgear.com/000062418/R7000-Firmware-Version-1-0-11-110
    You can also download the appropriate manual for your router:
    https://www.netgear.com/support/product/R7000.aspx#docs
    It's well documented that the check firmware function isn't accurate and will tell you there isn't a firmware update when there is. Why Netgear don't get their firmware developers to sort this out, is anyone's guess.
