InterociterOper
Jan 02, 2021Aspirant
R7000 Devices Website shows no firmware update needed....
I got a notice my firmware for my R7000 needed an update, but checking with my devices webpage, it says there is no update available, even though I am running 1.0.9.... Firmware Version V1.0.9.88_1...
- Jan 02, 2021
isn
InterociterOper wrote:I got a notice my firmware for my R7000 needed an update, but checking with my devices webpage, it says there is no update available, even though I am running 1.0.9....
Firmware Version
V1.0.9.88_10.2.88How do I get this fixed?
I don't want to put another #$%# app on my phone.
Also, the firmware update zip file I downloaded shows "shard" files????? Is that right?
If I brick this thing there will be no end of "heck" to pay.
Your device is 3 firmware upgrades behind going by the firmware update you have referenced. The latest firmware is:
https://kb.netgear.com/000062418/R7000-Firmware-Version-1-0-11-110
You can also download the appropriate manual for your router:
https://www.netgear.com/support/product/R7000.aspx#docs
It's well documented that the check firmware function isn't accurate and will tell you there isn't a firmware update when there is. Why Netgear don't get their firmware developers to sort this out, is anyone's guess.
antinode
Jan 02, 2021Guru
Probably. Which "the firmware update zip file" was that? What,
exactly, was in it?
"shard" is a double translation of "fragment"?
Don't be misled by what your operating system says when it sees
".chk" (or ".img"). Following the instructions in the router
documentation tends to work better.
https://community.netgear.com/t5/x/x/m-p/2024597
> Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0, R7000|AC1900
> Smart WIFI Router
Not a router.
