NetworkGuy36
Jan 04, 2016Aspirant
R7000 DHCP not working after reboot
Hi, I have a really weird issue. I have a the following setup: Internet: Comcast Cable Model: Motorola SB6141 Hardware V7.0 Firmware: SB_KOMODO-1.0.6.14-SCM03-NOSH Router: Nighthawk R...
- Jan 04, 2016
Problem Solved:
I am still not sure what caused it or what fixed it.
I power cycled the entire network and all of the attached devices. Turned everything off and the started powering up from the Cable Moden inward. When I was finished everything was back to normal.
I power cycled the modem and router yesterday with no effect. Not sure why reseting the entire network made a difference, but it did.
Thanks,
John
netwrks
Jan 04, 2016Master
If you can't set the SB6141 to bridge mode, then set the 7000 to AP mode.
NetworkGuy36
Not possible, the SB6141 is ONLY a DHCP server and not a router.
- Retired_MemberJan 04, 2016
NetworkGuy36 wrote:Not possible, the SB6141 is ONLY a DHCP server and not a router
Connect modem to PC with PC lan set to DHCP Reboot modem and PC this should assign a public IP to the PC.
Push router reset until power LED flashes this will erase all user settings, connect PC to lan port reboot PC. Should get a 192.168.1.xxx IP
Log in to router 192.168.1.1 got to setup.....internet setup.......USE PC MAC ADDRESS
connect modem to router WAN port reboot router follow the directions
- NetworkGuy36Jan 04, 2016Aspirant
Problem Solved:
Thanks,
John
