NetworkGuy36
Jan 04, 2016Aspirant
R7000 DHCP not working after reboot
Hi, I have a really weird issue. I have a the following setup: Internet: Comcast Cable Model: Motorola SB6141 Hardware V7.0 Firmware: SB_KOMODO-1.0.6.14-SCM03-NOSH Router: Nighthawk R...
- Jan 04, 2016
Problem Solved:
I am still not sure what caused it or what fixed it.
I power cycled the entire network and all of the attached devices. Turned everything off and the started powering up from the Cable Moden inward. When I was finished everything was back to normal.
I power cycled the modem and router yesterday with no effect. Not sure why reseting the entire network made a difference, but it did.
Thanks,
John
NetworkGuy36
Not possible, the SB6141 is ONLY a DHCP server and not a router.
Retired_Member
Jan 04, 2016
NetworkGuy36 wrote:Not possible, the SB6141 is ONLY a DHCP server and not a router
Connect modem to PC with PC lan set to DHCP Reboot modem and PC this should assign a public IP to the PC.
Push router reset until power LED flashes this will erase all user settings, connect PC to lan port reboot PC. Should get a 192.168.1.xxx IP
Log in to router 192.168.1.1 got to setup.....internet setup.......USE PC MAC ADDRESS
connect modem to router WAN port reboot router follow the directions
- NetworkGuy36Jan 04, 2016Aspirant
Problem Solved:
Thanks,
John
