Java_man
Jun 28, 2022Aspirant
R7000 DHCP question
I checked my R7000 log this morning and saw this: "[LAN access from remote] from 192.144.226.157:26559 to 192.168.1.2:80, Tuesday, Jun 28,2022 03:33:38" Reading through the logs I see multiple e...
Jun 28, 2022Guru - Experienced User
Do a who is lookup on 192.144.226.157
What FW version is currently loaded?
- Java_manJun 28, 2022Aspirant
Thanks for the reply.
Netgear FW: V1.0.9.88_10.2.88
I looked up a couple of the IPs and they were an ISP in England - pptechnology.
Modem: Motorola Surfboard SB6120 connected to Comcast.
Also noticed they're all connecting to 192.168.1.2:80 (port 80 - the HTTP port).
- FURRYe38Jun 28, 2022Guru - Experienced User
What devices has the address 192.168.1.2?
That's just it. . . none of them. I pinged the address and get no reply messages.
It's not listed in my "Connected Devices" page in the Netgear software either.
Pinging 192.168.1.2 with 32 bytes of data
Reply from 192.168.1.100: Destination host unreachable.
Reply from 192.168.1.100: Destination host unreachable.Ping statistics for 192.168.1.2:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Gotta step out for a couple hours. I'll check in when I get back.
Thanks again.
I did a little more digging in the logs. Here are a few examples:
[LAN access from remote] from 2.57.122.209:17773 to 192.168.1.2:80, Monday, Jun 27,2022 07:37:33 PPTECHNOLOGY LIMITED
[LAN access from remote] from 185.196.220.70:50551 to 192.168.1.2:80, Monday, Jun 27,2022 07:10:34 = HOSTLICK - Germany (AbuseIPDB: This IP was reported 1,076 times. Confidence of Abuse is 12%)
[LAN access from remote] from 221.176.116.78:20647 to 192.168.1.2:80, Monday, Jun 27,2022 07:09:36 = China Mobile Communications Corporation - ISP (AbuseIPDB: This IP was reported 663 times. Confidence of Abuse is 100%)
[LAN access from remote] from 154.89.5.87:58914 to 192.168.1.2:80, Monday, Jun 27,2022 06:39:43 = AgotoZ HK Limited (AbuseIPDB: This IP was reported 1,132 times. Confidence of Abuse is 100%)
[LAN access from remote] from 128.1.248.46:18057 to 192.168.1.2:80, Monday, Jun 27,2022 06:35:25 = Zenlayer Inc (AbuseIPDB: This IP was reported 14,921 times. Confidence of Abuse is 100%)
Hmmm...
Would be curious to see what happens if you set the default DHCP IP address range to 192.168.1.100 to.200.
Has a factory reset and setup from scratch been performed since you updated FW?
Something would be using .2 I believe. What browser are you using? Try MS Edge or Firefox and see what's seen in Connected Devices.
